Water cooling loop
Go to solution Solved by GoldenLag,
11 minutes ago, Hoofy said:
I know it’s not the efficient way I just like the aesthetics of the piping so I was trying to incorporate more of it in the case.
Providing there is a pump in the loop. And the loop doesnt have a seperate loop that goes outside of it. Then it should be fine.
So I’ve been planning my first loop for a little but  ran into this question that has kept me from starting it. I have my straightforward loop (which I uploaded) but I wanted to get a little more tubes ran in my case just for looks. I bought 2 reservoirs that will be mounted as seen in picture but didn’t know if my loop would work with multiple tubes running in the same res. Basically can someone look at my drawling and see in their opinion if it would work or would my pressure be all wonky.
https://linustechtips.com/topic/1074925-water-cooling-loop/
As far as i can tell the CPU wont get waterflow if interpreting the drawing
Get the CPU and GPU in serial so they both get waterflow.
What you essentially got going on there is 2 seperate loops with one not having waterflow
https://linustechtips.com/topic/1074925-water-cooling-loop/#findComment-12662937
Ok cool. So like on those two square reservoirs though can I have the loop enter one of them twice? So if I went like res/pump—gpu—cpu—res—radiator—back to that same res—pump/res would that be ok? So it would enter that same res block twice in the same loop
https://linustechtips.com/topic/1074925-water-cooling-loop/#findComment-12663023
https://linustechtips.com/topic/1074925-water-cooling-loop/#findComment-12663059
