Right now I have a corsair obsidian 900D which I regret buying because of the weight, size and overkill, things that didn't bother me before I bought it. I have a standard ATX motherboard, 2 GPUs and a water cooling loop for the CPU and 2 GPUs, I also have a 480mm radiator at the top. I'm looking for a case which can fit all this in without being overkill and extremely heavy, a case with good cable management and can fit a 360mm radiator at the top and a 120mm anywhere else.
https://linustechtips.com/topic/107489-i-need-help-finding-a-case/
750D or Arc Midi R2 are good options.
Quote me to get a reply!
+1 for the 750D. It really is your best option :)
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
Phantom 530
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
Fractal Design Arc XL, 800D, 750D, Phanteks Enthoo Primo or the NZXT H440 (not sure about the 480mm rad though).
800d can only do 3*120
Yeah, idk that lol. I just threw that in there with the others...
sounds good
H440 has theoretical 480mm rad Support in The top if You remove your 5 1/4 bays :-)
H440 doesn't have a 5.25" bays and is only 475mm in length, so 480mm is not possible to have inside the case. Only up to 360mm just like the specification says.
I don't want a case that can house a 480mm radiator, just a 360mm, I'm trying to cut down on size where ever I can.
Take a look at Carbide Air 540, or H440 (February release), or the Arc Midi R2. Those are pretty good Mid-Tower cases.
Would the Carbide air be any good for a watercooled set up on the CPU and 2 GPU's, 2 240mm radiators and a reservoir/pump 5.25 Bay?
Edit: never mind I just saw a review on the air 540 and it won't suit my needs.
