I was just wondering how to turn on LED's/RGB on my PC case that I bought. I just wanted to see if I should use an RGB controller that some companies make or motherboard. I will be providing pictures, do I connect this controller that my case came with to the power supply? I've seen threads online to do that instead of connecting it to the motherboard. I don't see any specific ports the power supply can connect to it. Tell me if you can. Also, some of the images have file names on it that show some of the problem. Thanks. The image of the front of my PC shows that the fans on the front aren't spinning or don't show any LED's. The fan in the back aswell, it spins but doesn't light up.
specs are
i7 2600 3.40 GHZ
GTX1060 3GB OC PNY
P8H67-M PRO Motherboard (DDR3)
Thermaltake PSU
Gamdias Talos M1 case
Back of PC with controller on top left. do i connect it to the controller_.jpg
https://linustechtips.com/topic/1074374-case-rgb-question/
I'm not sure what connections your rgb controller has. To connect to your power supply directly, it usually uses sata or molex, which i can't tell from the pictures.
Either way, i recommend connecting to the motherboard, so you can take advantage of various RGB software & control it from your computer. If you plug it into the power supply only, then you can only control it with the built-in settings on the rgb controller
https://linustechtips.com/topic/1074374-case-rgb-question/#findComment-12658199
@MegaMaximus Your motherboard and components are way to old to use any sort of RGB header, that case needs a newer motherboard with an rgb controller on it to work. If you want that case to work you will have to upgrade to a newer CPU, Motherboard, and Ram combo.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1074374-case-rgb-question/#findComment-12658242
That case doesn't have a PSU connector it has to be controlled by an RGB controller/header on a compatible motherboard and OPs motherboard came out long before RGB headers. OP will have to upgrade their system or buy a different case that uses an internal hub and an IR controller and not an RGB header.
https://linustechtips.com/topic/1074374-case-rgb-question/#findComment-12658257
So yeah that's probably it, I probably need a motherboard that supports it and my P8H67-M pro is from like 2012 ( i bought it in 2018 with a new computer) but it's a pretty old motherboard still. Thanks guys, I will try and figure this out. Do cases that have RGB designs on them have specific wires/cables that connect to the motherboard?
https://linustechtips.com/topic/1074374-case-rgb-question/#findComment-12658370
Yeah I think that's it, I got my new 8700k, z390 phantom gaming 6 and some ram in the mail, I was looking to replace this DDr3 motherboard and CPU, thanks for the response
https://linustechtips.com/topic/1074374-case-rgb-question/#findComment-12658374
