Raid 5 Help
Solved by Windows7ge,
If you're on a 1Gig network and have a very small number of clients you won't see much of a difference at all. You're probably better sticking with spinning platters in that case.
Performance benefits are really going to depend on what's controlling the RAID. Are you using a hardware controller? Software? If software. what type? What file system?
Theoretically you could replace the disks one at a time with SSDs you'd just have to expand the volume once you finish adding them all. However if the cumulative SSDs hold less than the HDD's storage I'm not certain you can do that. I think you'd need to move the data somewhere temporarily and just outright destroy and rebuld the array with new drives but don't quote me on that.
