Does overclocking damage a CPU if done properly?
Go to solution Solved by Wolly9102,
Just now, Collinator24 said:
Hello, I recently overclocked my 9700k @ 5.0Ghz, and it stays at about 30-40 degrees C idle and usually doesn't go over 80 degrees in almost any scenario. Is this going to reduce the lifespan of my CPU that much?
No. 80 degrees isn't that high anyway ;)
Main PC:
CPU: AMD Ryzen 7 5700X3D | RAM:Corsair LPX 3200 mhz (32GB)
Mobo:ASUS Strix B550-F Wifi | GPU: Gigabyte 9070
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Cooler Master GX III Gold 750
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Crucial 16 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
7 minutes ago, Collinator24 said:
Thanks, Just Checking For My Own Sanity :)
NP :) only 3 things kill CPU's
1 (too) high temperature in excess of 100 degrees Celsius
2 (too) high voltages
3 short circuit
Main PC:
Main Laptop
Second Laptop
GPU: IrisXe 80 eu
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
3 short circuit
Actually, a high temperature IS 80c.
Most people who overclock tend to not wanna get anywhere near it, and 70-75 is a hard limit, any more and it could significantly reduce the chips lifespan.
As for the high voltage, unless you constantly supply 1.6v or higher then for the most part, if your temperatures are in check, you should be good.
Not sure how you'd short your cpu, maybe with a faulty mobo or a dying power supply going straight through the shitty boards VRM
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
If you have not delidded your cpu yet, and you want it to last as long as possible and dont mind maintenance every few months (4 or so) then I recommend delidding and using Liquid metal (If youre daring) or some non-conductive paste, anything is better than intels TIM. Another test you could do is see if you can spin your cpu like a tabletop, or see if it is uneven in any other way, you can use sandpaper to even the surface out and get better contact between the heatsink and the cpu, thus lower temps.
Specs v-v
I'm not really looking to delid my 9700k atm. I forgot a made a separate thread about this, but in my opinion, I think an absolute max temp of 80 is fine and I would dial it back if it went to 85, as 80 is the highest I have seen it. It usually stays at ~78c max load. see (
80 isn't that hot.
Most mobile CPUs are teetering on the edge of thermal throttling and are way above that. And they are generally fine.
Current does more to hurt CPUs than an 80c spike.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
1 hour ago, Plutosaurus said:
80 isn't that hot.
80c being pro-longed. Current or Voltage? I'm sure you mean voltage.
Specs v-v
80C under 1.4v wouldn't "damage" the cpu, but running it 24/7 load might degrade it over time. I wouldn't worry about it though. In theory if i had to run a 9700k/9900k on full load 24/7 i'd do it on 1.1v 4.5 for efficiency (electric bills).
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Yeah no, I almost never put it under synthetic load and the most intensive thing I do is render with sony vegas and that only brings temps to a max of 62 degrees ;) Also, @krysta24 The maximum temp I have seen is 80C, and I haven't seen it go back to it personally. I am not running 80C prolong, to clear up some things. The max I usually see is about 63 degrees. I saw 80 in synthetic benchmarks and then it went down when the fan curve detected 80C. tjmaxx temps for this chip is 100C so I don't think it's really an issue. and watching YouTube only gives me 40C which is usually what I do the most.
