YAY the FORUM works today
time to upload my build.
Parts
  • CASE: Coolermaster CM690II Advanced
  • Motherboard: Gigabyte GA-990FXA-UD7
  • CPU: AMD FX8150 AM3+
  • RAM: 16GBs of 1600Mhz CL8 RAM
  • HDDs: 2TB WD black, 2x1TB WD Green, 2x2TB WD Green, 1x3TB WD Red
  • Video Cards: 2xEVGA Nvidia Geforce 480 1.5Gb with AXP coolers with modded EVGA backplates
  • PSU: Coolermaster 1000W Silver Silent Pro 1x80Amp 12V Rail (easy to setup)
  • Fans: 3x Aerocool 12CM Shark Blue Edition, 5x Aerocool 14CM Shark Blue Edition
  • Fan Controller: Neateq FanMax 8 channel fan controller.
Photos
Without much cable management
With just some cable tyes (very handy)
some Photos with the side off and powered off
Front View
Right hand panel on and all those cables are hidden
Front View with Power ON
Side view with power on and side panel on
So let me know what you guys think and also what would you recommend next?
I was thinking of a custom water loop for the CPU.. and eventually when i get new Graphics cards adding some GPU blocks..
what Parts would you recommend? i haven't done water cooling before so i have no idea what to buy or where to look...
Note: i'm a Aussie :P
Also i will upload some more pics later of it at night :D
https://linustechtips.com/topic/10739-project-silver-90/
I personally don't think messy cable management is bad if you can't see it (so it's either behind the mother board or you don't have a window) and it doesn't mess with air flow. That said, the red wire visible through the fan mount on the right side of the case bugs me :P Other than that sweet build.
https://linustechtips.com/topic/10739-project-silver-90/#findComment-124417
Very pretty!!! :D and love that sexy cpu cooler :)
Intel Core i7-3770K @ 4.9GHz |--| Gigabyte Z77X-UP7 |--| 16GB Crucial BalisitX Elite @ 1600MHz |--| Sapphire + Gigabyte HD 7990 in Quad CrossfireX @ 1,100MHz |--| Samsung 840 Series 250GB SSD |--|  2x Seagate Momentus XT 750 GB HDDs in Raid0 |--| CoolerMaster V1200 Platinum |--| Corsair Obsidian 750D
"There is no heaven or afterlife for broken-down computers; that is a fairy story for people afraid of the dark." - Stephen Hawking
https://linustechtips.com/topic/10739-project-silver-90/#findComment-125284
That cooler is a beast. Looks great!
Zephyr:
3770k (Stock clock) w/ Zalman CNPS9900MAX-R | 16GB DDR3 @ 2133Mhz | 2x Radeon HD 6950 (Reference, stock clock) | Asrock Fatal1ty Z77 Professional | Thermaltake Toughpower Grand 1200w | 60GB SSD Boot, 750GB HDD Media, 1TB HDD Programs
https://linustechtips.com/topic/10739-project-silver-90/#findComment-126040
  • 2 weeks later...
hey all..
thanks for all the replies...
I was away for just over 2 weeks and just got back.
Thanks, Just noticed that.... will have to move it :P.
I have seen water cooling systems done in the CM690II before without much issue... I was even looking at a top mounted Radiator then running the pipes back into the case through the provided holes (there are 2 above the rear 120mm FAN)
A can of air duster will help that case alot..
I just ordered some :)
I loved my 690II, you should get the clear side panel to show off your rig instead of the regular one.
Sadly i am in AUS... and i can't get one... would love one though
Is that a cup warmer on top of the case? Nice build but looks a bit cramped for a decent water cooling system. Those things can be pretty big with the reservoir, piping, pump and radiator unless you go for the pre-assembled kits.
it's a USB hub and Card reader...
It does look good and perform well.... thanks
https://linustechtips.com/topic/10739-project-silver-90/#findComment-165241
