I´m starting a new set up with so low budget.
Really needs help to find a good setup.
I´m planning to get a pc that in a future can be upgraded, my first thinks was to get a rx 570 8gb cuz is better than the 1050ti and it´s cheap where I live (I´m from Argentina and the components here are so expensive)
Them I started to  think "I have no idea which motherboard, cpu, ram, and power supply should I buy... so, if you can help me guys, I´ll thanks you a lot!
Is this a good option?
Mother Asrock X370M-HDV + Procesador AM4 A10 9700 + 8GB 3000MHz XPG
And between this two power supplies, if they can be used with this setup, which one is better?
compragamer_Imganen_general_6822_Fuente_Corsair_550W_CX550M_Semi_Modular_80_Pluz_Bronze.jpg.50d3c3b2829b5c0b72cbd54560e7c4b0.jpgxD.jpg.b195ea834e15f142c141ddb321caf403.jpg
https://linustechtips.com/topic/1073862-first-pc-with-low-budget-help/
