I’d like to run MacOS Catalina on my pc, but I know only VERY VERY little about Hackintosh-ing. I know Intel chips are the most widely supported (I think? Correct me if I’m wrong) But I wanted to know if it would be possible to run MacOS Catalina (or at least Mojave’s on my system.
Specs are in sig if needed.
Thanks in advance everyone.
I got a ps5 and a pc pretty ballin
https://linustechtips.com/topic/1073649-i-need-basic-advice-with-hackintosh/
This is a great resouce: https://www.tonymacx86.com/
Question: Why would you want to use MacOS? If you search an alternative to Windows and don't care about the Apple-special features (of which many are impossible on macos anyway):
Go for Linux. Many Desktop Environments are very much like MacOS when it comes to handling.
elementaryOS for absolute beginners or KDE Neon for being heavy customisable without having to use Terminal/Commands.
I don't have high hopes for it, but it might work. TonyMacX86 strictly prohibits discussion about AMD hackintoshes, this is the site you need instead: https://amd-osx.com/
I wouldn't expect Catalina to work, but an older version might
