Noise Isolation Gaming headset
Solved by rice guru,
M50x has no soundstage barely any separation and no imaging while the 770 has great imaging a surprisingly wide sound stage with shimmering highs and a strong low end.33 ohm if you plan on using it mobile, 80 ohm if your on your PC but don't have an amp. If you have an amp grab the 250 ohm. A good cheap mic to go with it is the blue snowball, or a antlion modmic. A modmic might be better if your in a noisy environment as the snowball will pick up everything
