PCIe lane allocation and speed with older standard
Solved by GoldenLag,
1 minute ago, Sharpman85 said:So the 8/16 lanes will run at the speed of the device connected? That cleares a lot of confusion from my side, thank you.
yes. it will run at the slowest of the connected ends.
2 minutes ago, Sharpman85 said:I know, but the itx model had them only connected to the CPU and the backside one shared lanes with the GPU.
highly dependant on which model we are talking about. there is usually a CPU NVMe, unless the mobo vendor redirected it.
