connecting a 2nd subwoofer
Killerbenny04
Hey, so i recently bought a new sound system. https://www.logitech.com/de-de/product/z607-surround-sound-system
and i wanted to connect an old subwoofer of mine paralel to that. And both connect via 3.5mm audio jack. How would i do that the best? Thanks ^^
Ryzen 5 1600 Stock
Gainward GTX 1060 Stock
ASUS Prime B350 Plus
8 GB DDR4 2133 MHz Gskill
Be Quiet! 400 Watt unit
Corsair Carbite SPEC 03
My Old shitty System :
Intel Core I3 530 4x 2,93 GHz
NVIDIA GeFroce GT 330 750 MB VRAM
4 GB (2x2) Samsung DDR3
Sorry for my English. I'm from Germany !
If the new sub connects by 3.5mm then it should have a low pass filter built in, so you can just split the 3.5mm for the centre/sub and send one to the z607 and one to the other sub
LTT's Resident Porsche fanboy and nutjob Audiophile.
Main speaker setup is now;
Mini DSP SHD Studio -> 2x Mola Mola Tambaqui DAC's (fed by AES/EBU, one feeds the left sub and main, the other feeds the right side) -> 2x Neumann KH420 + 2x Neumann KH870
(Having a totally seperate DAC for each channel is game changing for sound quality)
