gskill warranty is very good, do you have backup ram while it's in transit?
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Is it both sticks or just one that error out? If it's just one you may be able to just send it back and continue using the good one. But yes, send them back if possible.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
is this why im having an fps drops in games?
hard to say, we do know that memtest is not supposed to get errors like that, you can try 1 stick at a time, lower speed etc. or if it's not worth ur time at all, just RMA it.
alright. im thinking of going with corsair this time. this is the second set i got from the RMA any corsair recommendation?
if it's the second set, at least try switching the slots the ram is in to make sure it's not the slots, could also be the memory controller/motherboard, but would need a new motherboard to test that.
For corsair ram, pick one with good reviews, doesn't really matter with intel unless you are minmaxing
https://www.newegg.com/p/pl?N=100007611 50001459 601190328
