so  im hear again needing more pc help i just built my pc at xmas so i am a bit new but have a breif understanding of pc, so my issue is that i want to upgrade my storage and i wanted to get another m.2 as they way faster that ssd i allready have a m.2 ssd in the slot the ,i only have one m.2 slot on my motherboard so i was thinking of getting a pcie 3.0 m.2 card for more space but i have an issue, my mobo asus strix b350-f has only 20 pcie lanes 16 for gpu the 4 for the m.2 slot
so i dont have any lanes left. the mobo has 2 x PCIe 3.0/2.0 x16 (x16 or x8/x4) the x8 and x4 is if i put a gpu in the second slot and. the other slots are connected to the chipset 1 x PCIe 2.0 x16 (max at x4 mode) and 3 x PCIe 2.0 x1  3 x PCIe 2.0 x1. and when useing the m.2 slot my sata pots 5/6 are dissabled.
so i want to add a x16 pcie 3.0 m.2 card can i do this without makeing my gpu go slower
or if adding a x16 m.2 card slow down my gpu or is it only if you put a gpu in the secondary slot that it slows down your gpu in the first slot?
dont know need help plz
and does adding a m.2 card slow performance of the gpu/
rig
asus strix b350-f
ryzen 5 1600
rx 580 gpu
samsung m.2 ssd 970 evo pluss
https://linustechtips.com/topic/1073076-m2-storage-help/
the chipset is also a pcie hub, so there are anouther 8 or so lanes from that.
It won't, as you can't split the main x16 on b350
If you want another m.2, just get a pcie to m.2 adapter, and run another drive. It will run at pcie2 x4 but, the speed really won't matter.
https://linustechtips.com/topic/1073076-m2-storage-help/#findComment-12647743
so what port should i use for the adapter and can it be a x16 slot? and can i use my m.2 as a boot drive in the expantion card
and is getting a pcie 3.0 x16 ok even if it runs ar x 4 speed?
https://linustechtips.com/topic/1073076-m2-storage-help/#findComment-12647751
Get an adapter like this https://www.amazon.com/EZDIY-FAB-Express-Adapter-Support-22110/dp/B01GCXCR7W/ref=sr_1_4?keywords=pcie+to+m.2&qid=1560624249&s=gateway&sr=8-4
It will work fine in a x16 slot.
You can boot form that.
It will run at x4 with this adapter, jut only at pcie2 speeds
What drive do you have now? What drive do you plan on getting?If its just a game drive, id get a cheaper m.2 like a 660p.
https://linustechtips.com/topic/1073076-m2-storage-help/#findComment-12647756
i have a 970 evo pluss and getting another one for games/ files and will speed be slower on m.2?
https://linustechtips.com/topic/1073076-m2-storage-help/#findComment-12647772
yea, the second drive will be slower as its only pcie gen 2 x4, not gen 3.
Id get a cheaper m.2 drive personally or a sata ssd, the performance won't matter much.
https://linustechtips.com/topic/1073076-m2-storage-help/#findComment-12647775
ok thanks for help my friend help lots good day bro
https://linustechtips.com/topic/1073076-m2-storage-help/#findComment-12647791
sorry one more question can i use this m.2 for now and future profing as i will be getting x470 soon
https://www.amazon.co.uk/ASUS-Hyper-M-2-Card-Socket/dp/B07PCKTL1J/ref=sr_1_4?crid=3VO2FWBHBO53H&keywords=asus+m.2+adapter&qid=1560710758&s=gateway&sprefix=asus+m.2%2Caps%2C139&sr=8-4
https://linustechtips.com/topic/1073076-m2-storage-help/#findComment-12650018
1 hour ago, atg117 said:
You need a system tht supports pice bifurcation to use that card, so don't get it.
If you go x470, it won't support those cards, there made for systems like threadripper and x299, with many more pcie lanes.
Why would you get x470? Your not really getting much more unless you want dual gpu.
https://linustechtips.com/topic/1073076-m2-storage-help/#findComment-12650200
oh ok thanks think i will just get more sata ssd
i was thinking on upgrading my mobo for more pcie lanes but i have looked into x470 and they dont look like it has to 2 3.0 pciex16 slots runnin at x16 speed just wanted more pcie lanes for upgrade ability i might just save a wait for x570 if the price is right doubt it tho
https://linustechtips.com/topic/1073076-m2-storage-help/#findComment-12650223
getting x570 or x470 won't give you any more pcie lanes, thats limited by the platform, so go threadripper or x299 or dual socket if you need more pcie lanes.
But why do you need more pcie lanes? You have more than enough for a gpu + 2 pcie ssds.
https://linustechtips.com/topic/1073076-m2-storage-help/#findComment-12650267
