VS 2017 HELP!!!!
Go to solution Solved by FlappyBoobs,
In the view menu there is an option to turn on "solution explorer" that's most likely what you want. I think it may be in a sub menu but thats the name you need to look for.
thank you so much!
https://linustechtips.com/topic/1073063-vs-2017-help/#findComment-12647682
1 hour ago, itchkowb said:
This has been solved
Just heads up but always leave your question or problem up as people may encounter the same issue in the future and can find the forum post through the forum search or google search. This can make it significantly easier for others to solve the same problem no matter how trivial it is.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
https://linustechtips.com/topic/1073063-vs-2017-help/#findComment-12647816
