Alright so a few months ago I bought a Dell MD1200 off ebay. It's worked great until now but as things are changing and moving around I need a replacement for it as it is just far far too loud in its new location. I would prefer a DAS option to just straight up replace it as it's attached to my R710 and quite integrated into everything.
Any suggestions?
Use this guide to fix text problems in your postGo here and here for all your power supply needs
New Build Currently Under Construction! See here!!!! ----->
Deathwatch:[CPU I7 4790K @ 4.5GHz][RAM TEAM VULCAN 16 GB 1600][MB ASRock Z97 Anniversary][GPU XFX Radeon RX 480 8GB][STORAGE 250GB SAMSUNG EVO SSD Samsung 2TB HDD 2TB WD External Drive][COOLER Cooler Master Hyper 212 Evo][PSU Cooler Master 650M][Case Thermaltake Core V31]
Cupid:[CPU Core 2 Duo E8600 3.33GHz][RAM 3 GB DDR2][750GB Samsung 2.5" HDD/HDD Seagate 80GB SATA/Samsung 80GB IDE/WD 325GB IDE][MB Acer M1641][CASE Antec][[PSU Altec 425 Watt][GPU Radeon HD 4890 1GB][TP-Link 54MBps Wireless Card]
Carlile: [CPU 2x Pentium 3 1.4GHz][MB ASUS TR-DLS][RAM 2x 512MB DDR ECC Registered][GPU Nvidia TNT2 Pro][PSU Enermax][HDD 1 IDE 160GB, 4 SCSI 70GB][RAID CARD Dell Perc 3]
Zeonnight [CPU AMD Athlon x2 4400][GPU Sapphire Radeon 4650 1GB][RAM 2GB DDR2]
Server [CPU 2x Xeon L5630][PSU Dell Poweredge 850w][HDD 1 SATA 160GB, 3 SAS 146GB][RAID CARD Dell Perc 6i]
Kero [CPU Pentium 1 133Mhz] [GPU Cirrus Logic LCD 1MB Graphics Controller] [Ram 48MB ][HDD 1.4GB Hitachi IDE]
Mining Rig: [CPU Athlon 64 X2 4400+][GPUS 9 RX 560s, 2 RX 570][HDD 160GB something][RAM 8GBs DDR3][PSUs 1 Thermaltake 700w, 2 Delta 900w 120v Server modded]
RAINBOWS!!!
 QUOTE ME SO I CAN SEE YOUR REPLYS!!!!
https://linustechtips.com/topic/1072618-replacement-for-md1200/
Any suggestions?
I have an MD1200 and can confirm, they're as loud as jet engines - easily twice as loud as my T410 or x3650 M4 servers.
As others have said, you can try modding the fans with resistors.
Otherwise, there's not really a good solution for a "true" purpose built DAS, since they're usually all loud, and the good ones are super expensive (MD1200's go for $400+ CAD on eBay on the low end typically - with most of the listings being closer to $700+ CAD).
9 hours ago, leadeater said:
If you want to get very quiet the only option is to make a custom JBOD using a Supermicro chassis and external to internal SAS HBAs otherwise modding standard disk enclosures is all you can do, none of them are quiet.
Creating a custom "DAS" using a Server chassis like this is probably the "best" way to create a good quiet chassis.
I've considered replacing my MD1200 with a custom built one - but the MD1200 is just so goddamn bullet proof.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
https://linustechtips.com/topic/1072618-replacement-for-md1200/#findComment-12647265
