3x4Pin??
Go to solution Solved by TheStyne,
What is your power supply make and model?
You'll be fine with just the 2x4(8 pin) power cable. The extra 4 are just for extreme overclocking. I'm mostly just curious about the make and model, and it won't affect the power cable question.
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
https://linustechtips.com/topic/1072541-3x4pin/#findComment-12643395
its a 500W pure power 11 from BQ :) thx 4 the answer! :)
https://linustechtips.com/topic/1072541-3x4pin/#findComment-12643434
I have that motherboard. Can confirm it works with just the 4 pin or just the 8 pin. I currently use just the 8 pin on a Ryzen 5 2600 @4.15hz and 1.375v. I've run it as high as 1.45 trying to get higher, but just can't do it reliably without way more voltage than it's worth. But the motherboard and CPU both survived cinebench and prime95 at 1.45 without any unusual VRM temps.
https://linustechtips.com/topic/1072541-3x4pin/#findComment-12643492
