Alarm System
Solved by Windows7ge,
I'm pretty sure no popularly distributed application like this exists. The use case is too unique.
You may want to look into something like a micro-controller or an arduino. That'd be more ideal for this application.
Some alarm systems already connect to your Wi-Fi and have the ability to send you a phone notification. This would probably be the easiest of all 3 since if you used your PC and a mic you'd have to code what audible dB and/or frequency range would trigger sending you a notification and that requires background knowledge in coding.
