Hi there.
I recently bought a Inno3d 2070RTX Twinx2, and the cooling is so bad, so i want a AIO watercooler for the graphic card.
I asked the company and they said "find one that fits with the NV PG160 reference design".
I am not the best tech guy, so i hoped that someone could help me here?
https://linustechtips.com/topic/1071494-please-help/
oh, that would be easy if that would fit the card, but the 2070RTX are not listed as a compatible?
Compatibility - Graphics Cards
Nvidia
GeForce RTX 2080*, 2080 Ti*, Titan X, Titan, Geforce GTX 1080 Ti, 1080, 1070, 1060, 980 Ti, 980, 970, 960, 780 Ti, 780, 770, 760, 680, 670, 660Ti, 660, 580, 570
Known Incompatibility - Graphics Cards Nvidia
GeForce RTX 2060
https://linustechtips.com/topic/1071494-please-help/#findComment-12634001
3 hours ago, JonasDenmark said:
yea, i saw a video about it, BUT it would be much easier if there was one that just fitted, but i think i will take the G12 and drill new holes ?
If it's a reference designed card it should usually fit but hard to say exactly without a test fit, here's a PCB layout which may give some more information.
Inno3D RTX 2070
INNO3D GeForce RTX 2070 Twin X2, 8GB GDDR6,  (N20702-08D6-1160VA22)
https://linustechtips.com/topic/1071494-please-help/#findComment-12634450
