Depending on the stickiness of the particular compound you choose yes, technically.
But it would add virtually 0 extra benefits while making the CPU harder to handle.
Not to mention if you use a electrically conductive compound and it happened to ooze out.
You're better off with a little silicone. If you concern is getting back in again then use less silicone.
I see..
I've got Thermal Grizzly Kyronaut and it has, quoting there website : " no electrical conductivity!!! "
So I think I'll use that. I'll see if it works.
I don't have any silicone or glue so..
EDIT: Do you think the fact that it will conduct heat from the IHS to the plastic is a problem ?
Edited by MilaweaX
Adding a question
