Hi, so my laptop has done this for a while, but recently it has been pretty bad, I have to restart my laptop almost every day because of memory leak. I have 16GB of RAM, yet it said I was using 95% in Task manager with only a few programs plus Windows, the numbers don't add up. But if I do a restart then it's down to where it belongs. image.png.9b4672963510cec6832bc99c6c305660.png
https://linustechtips.com/topic/1071068-crazy-memory-leak/
A quick question... perhaps a Killer Nic / WiFi in that thingie?
There was a time not long ago where killer drivers were nomming up ram.
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
https://linustechtips.com/topic/1071068-crazy-memory-leak/#findComment-12630444
Any change if you go to the Details tab and sort by Memory?
https://linustechtips.com/topic/1071068-crazy-memory-leak/#findComment-12630445
Are you showing all processes? I had an issue like this with Windows 10 a while back that also coincided with a lot of disk use all the time, the OS was generating hundreds and thousands of log files into RAM then flushing them to disk, it also took a long time to shut down. They were all very small in size so it would have taken millions of them for me to notice a loss in disk space. I was able to sort all the processes by disk use, then google which one it was, then find some others who had ran into the issue, and the solution was very simple. You just deleted all the the files in a directory after stopping the service. The root cause was some kind of broken update that corrupted a file and caused the process to fail and log the fail in the background endlessly. Crazy stuff!
https://linustechtips.com/topic/1071068-crazy-memory-leak/#findComment-12630460
It may have been that same service for me, that sounds familiar. It's obviously not running a scan because there's low CPU use, go to the performance tab and check disk use, is the PC mostly doing writes constantly? If you can end the service then do so, it'll probably restart but check the memory use to see if it dropped when you ended the service running and then over time slowly creeps back up. If both then it sounds like the same issue I had.
https://linustechtips.com/topic/1071068-crazy-memory-leak/#findComment-12630514
That's not what your screen shot of task manager shows when ordered by disk activity from greatest to least. If you end the process with the greatest disk writes, does the memory use in the performance tab also change? Not all memory consumed is visible to you in task manager by process so plainly as you'd expect. This sounds very similar to the issue I was experiencing, but it was almost a year ago and I've forgotten the specifics, I can only recall my trouble shooting process and the findings that led me to the solution.
https://linustechtips.com/topic/1071068-crazy-memory-leak/#findComment-12632082
