Hey guys,
Iv'e got a problem with my screen and I don't know how to fix it (It's won't turn on, even the LED).
So i opened my screen and start to disconnect every cable I can see XD
When I disconnected the cable in the picture the little LED has started to work.
Now I don't have any idea what causing this issue, If someone can help me I would be thankful.
P.S. if someone know how this cable is called it would be really helpful :)
https://linustechtips.com/topic/1070902-screen-problem/
Thats a flat ribbon cable.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
https://linustechtips.com/topic/1070902-screen-problem/#findComment-12629174
Do you happen to have a multimeter?
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
https://linustechtips.com/topic/1070902-screen-problem/#findComment-12629233
