so i recently started playing minecraft again,because why not and im running into some problems
i just created an amplified world and im getting about 20-25 fps while i can't see any bottleneck
here's what im seeing:                            (note: high ram usage is because of chrome xd)                          (note#2: render distance is 64 chunks)gpu.thumb.JPG.56ca73f1f880bab15e9662143444c2f1.JPG
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1070141-problems-with-minecraft/
1 minute ago, NinJake said:
What happens when you turn the render distance down? More stable frames?
sure the framerate does climb up to around 50 but i can't see a reason why it would do that since theres no bottleneck
Just now, eemunni said:
Do you have optifine installed?
yas
Just now, Origami Cactus said:
Multicore chunk loading enabled?
no idea xd
didnt help much
