Network speed ups and downs
Solved by deltaop852,
On 6/7/2019 at 1:26 AM, Tellos said:So this is on a LAN then? If so and no access to your modem for internet it could be the NIC on either side, could be the CPU the HDDs are very much slow down points and how great a distance is it and what type of Ethernet you using? Is one machine older than the other?
sorry i missed the reply till now.. yes lan it seems to have worked it self out. did some tweaking to the nics and that seems to be helping .. thanks
