6300 or 8320 if you can find one for cheap
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/107008-help-with-amd-cpu/#findComment-1430261
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/107008-help-with-amd-cpu/#findComment-1430262
Yup, just for the cpu.
Im gonna look at the 6300
Thanks guys
Anything else to look at?
if you wanna get a decent motherboard get the asus 970. http://www.newegg.com/Product/Product.aspx?Item=N82E16813131872
https://linustechtips.com/topic/107008-help-with-amd-cpu/#findComment-1430278
Thanks guys
Well for motherboard get a 990fxa-Ud3 really solid board for the price also get a hyper 212 evo to cool it (I did a review of it on the forum if your interested)
Review: http://linustechtips.com/main/topic/96747-my-review-of-the-cooler-master-hyper-212-evo/
Hope I could help!
https://linustechtips.com/topic/107008-help-with-amd-cpu/#findComment-1430286
750K, 760K, 6300, 8320.
Depends how much you want to spend.
https://linustechtips.com/topic/107008-help-with-amd-cpu/#findComment-1430314
So this is what I got so far for a decent AMD baded pc, Its for my girlfriend andd she wants a pc.
List:
MotherBoard - Gigabyte GA-900FXA-UD3 / $139.99
CPU - AMD FX-6300 / $119.99
RAM - Mushkin Enhanced Stealth 8gb 1600mhz / $79.99
Power Supply - Corsair CX600 / $69.99
SSD/HDD - Samsung 840 EVO / $109.99 Western Digital 1tb Blue / $59.99
Optical Drive - Asus optical drive / $18.99
Operating System - Windows 7 OEM 64 bit / $99.99
Case -
GPU - EVGA Geforce GTX 760 w/ ACX / $199.99
Again. Thanks for the help everyone!
Edit... Im trying to stay under 1000 usd
https://linustechtips.com/topic/107008-help-with-amd-cpu/#findComment-1430447
List:
Case -
 Where are you getting that 760?
https://linustechtips.com/topic/107008-help-with-amd-cpu/#findComment-1430521
I'll move the thread to New Builds and Planning since it seems like you're planning a build here now.
https://linustechtips.com/topic/107008-help-with-amd-cpu/#findComment-1430707
List:
Case -
I'm confused? This build doesn't seem that in line with "mild gaming, web browsing"
I mean I was thinking if that's the case just get like a
AMD II 750K
A88XN-WIFI (mini itx board)
This would save you around $60 and you get a WiFi adapter.
and stuff it into like a cooler master 110, or a node 304. Maybe Obsidian 250D? Or even a hadron
https://linustechtips.com/topic/107008-help-with-amd-cpu/#findComment-1431062
