Hello, all the good people!
I am wondering whether there is anything special about the soft tubing sold by places specializing in computer liquid cooling?
How does (if at all) this tubing differ from what we can get at Home Depot or Lowes?
Thanks for your time,
-z-
https://linustechtips.com/topic/1069860-soft-tubing-quality/
To my knowledge not particularly. You would need to watch-out if you use anything besides just distilled water & color additives as sometimes the materials certain tubings are made out of can break-down gumming up the loop or causing a leak when mixed with some chemical additives used in come coolants. A big one would be anything based on ethylene glycol. Certain PVC based tubings cannot be mixed with this as it chemically reacts breaking down the tubing over time.
Otherwise no there's nothing special that makes tubing designed for PC liquid cooling a requirement. You just have to be careful that you know what is in the tubing you buy.
https://linustechtips.com/topic/1069860-soft-tubing-quality/#findComment-12620555
-z-
Loop tubing = brand named expensive
Tubing that can be used in a loop = Food grade, non heat sensitive.  I.E. I just ordered (doing a black industrial theme build) food grade, beer making tubing.  Why?  Its for extreme heat, and doesn't leech chemicals/color into the liquid (food grade).  That's the basics.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1069860-soft-tubing-quality/#findComment-12620616
