Hello, I have a RTX2070 an i7-7800X and 32gb ram. I have tried to play GTAV but when I play it I get around (not steady) 30 to 45fps ingame. But not higher than that. Its really weird because all settings are normal and vsync is off. I dont actually understand this because my pc can easily handle GTAV. Also a friend of mine has a ryzen 5 and rx580 and he runs gta high settings 100fps easy so i dont understand this... please help me out!
Thanks in advance
https://linustechtips.com/topic/1068905-low-fps-gta-v/
4 minutes ago, Tristanv100 said:
thats not really help but ok thanks i guess
I'm just saying that I would probably run few programs that monitors cpu speed / temp, change power settings in Nvidia panel to Adaptive, checking BIOS OC settings (if you have any), install new GPU drivers, disable any game mode settings in Windows, uninstall any tool that suppose improve performance (if you have any installed), install dx redist, install chipset drivers, disable AV... So many things. It's hard to say what is wrong.
https://linustechtips.com/topic/1068905-low-fps-gta-v/#findComment-12613663
1 hour ago, Tristanv100 said:
Yes but there is nothing wrong with the settings for instance battlefield 1 is good on ultra, good fps. Assassins creed syndicate too. But why not gtav that is the oldest game of those 2
So check settings in game. Maybe vertical sync problem, maybe some advanced settings pushed too far.
https://linustechtips.com/topic/1068905-low-fps-gta-v/#findComment-12614674
It's probably your CPU. Despite being an expensive CPU, the 7800X isn't great for gaming (assuming it's at stock). Try running HWMonitor in the background while playing and see if anything hits 100%.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/1068905-low-fps-gta-v/#findComment-12614742
