As the topic suggests I'm looking for a 120mm fan for cooling a server case (3u Rackmount). The server rack is in my living room so it has to be reasonably silent. I got already some Noctua NF-A6x25 as an exhaust and an NH-L12 as CPU-Cooler. But as the temperatures are rising i need some cooling for the 16 HDD Bays in the front and some airflow through the case in general.
I can fit 3x 120mm fans inside so I was thinking about getting Noctua NF-F12 as they've got good static pressure. On the other side an NF-A12 would be a good choice as well since it has good static pressure and good airflow. (got that from the chart on noctua's website
What do u guys think? I am open for suggestions of other brands as well ;)
Main Rig
CPU - i7 6700 | RAM - 16GB (2x8GB) G.Skill, 16GB (2x8GB) Crucial OEM | GPU - MSI GTX 980 Gaming | PSU - Cooler Master G450M | Storage - 1x 256GB Samsung SM951 (NVMe)(System), 2x 500GB Samsung 860 EVO (Striped) | Case - Fractal Design Define R5 (with TG side Panel) | OS - Windows 10 Pro
NAS / Docker Host
CPU - Xeon E3-1220v3 | RAM - 16GB (2x8GB) Kingston ECC | PSU - Enermax Revolution SFX 550W | Storage - 3x 4TB WD Red, 1x 2TB WD Red, 4x 3TB Seagate Constellation, 2x 250GB Samsung 850 EVO (Cache) | Case - AVID Unity Media Engine (3U Rackmount) | OS - UnRAID OS Pro
VM Host
CPU - Xeon E3-1246v3 | RAM - 32GB (4x8GB) Samsung ECC | PSU - Enermax Revolution SFX 550W | Storage - 2x 512GB Samsung 860 Pro (System / "Fast" VM's), 4x 500GB HGST (RAID 10) | Case - Avid Unity MediArray XT (3U Rackmount) | OS - Windows Server 2019 Datacenter
Notebooks
Fujitsu Lifebook E756CPU - i5 6200U | RAM - 8GB DDR4 OEM | GPU - Intel HD 520  | Storage - 250GB Crucial MX500 | OS - Windows 10 Pro
Apple MacBook Pro Mid 2015 | CPU - i7 4770HQ | RAM - 16GB | GPU - Intel Iris Pro | Storage - 512GB Toshiba XG4 NVMe | OS - macOS 10.15.1
https://linustechtips.com/topic/1068310-best-fan-for-server-case/
NF-F12's would be better if you're planning on using most of the drive bays.
Noctua NF-F12 iPPC 2000/3000 then, they're server fans
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
