So I just bought a new PSU, a SeaSonic FOCUS Gold 550, and its great apart from one issue. The included PCI-e 8 pin cable has a rubber wrap right at the end (which is extremely stiff). This means the cable sticks out of the case by about 2 inches so my side panel can't go back on. Also, the cable has an extra 8 pin connector on it, and as I only need 1, it ends up looking messy. Is there any way to remove both this rubber wrap and the extra connector? I attached a picture.20190528_174846.thumb.jpg.1c882fe7779b932c42d983508ca316a7.jpg
https://linustechtips.com/topic/1067773-psu-cables-too-stiff/
Just bend the cable at the connector before the heatshrink.
It doesn't need to stick out.
https://linustechtips.com/topic/1067773-psu-cables-too-stiff/#findComment-12603292
Zip ties are your best friend.
It's not a race to the bottom.
https://linustechtips.com/topic/1067773-psu-cables-too-stiff/#findComment-12603620
