Ethernet Cables
Solved by scottyseng,
1 minute ago, WickedStarfish said:i just want to remove the packet loss that i suffer from playing games and all i can think of it being is the wireless connection, just am unsure as i have never used an ethernet cable before (other than small lan tasks (playing games with my sister like 8yrs ago))
Well, if you can afford it, I would get the 6A since you really aren't replacing cables much. $5 is not that much extra for 30m length.
I'm pretty sure it will solve your packet loss issue.
