Hi everyone, just looking for some feedback on my build. I'm pretty happy with where everything stands and only really want to change stuff if it's absolutely necessary.
PCPartPicker part list: http://au.pcpartpicker.com/p/2FCyz
-CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($275.00 @ PCCaseGear)
-CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler  ($88.00 @ CPL Online)
-Motherboard: Gigabyte GA-Z87X-UD4H ATX LGA1150 Motherboard  ($252.00 @ CPL Online)
-Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory  ($108.00 @ CPL Online)
-Storage: Samsung 840 EVO 250GB 2.5" Solid State Disk  ($189.00 @ PCCaseGear)
-Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($99.00 @ PCCaseGear)
-Video Card: Sapphire Radeon R9 280X 3GB Video Card  ($449.00 @ PCCaseGear)
-Wireless Network Adapter: Asus PCE-N15 802.11b/g/n PCI-Express x1 Wi-Fi Adapter  ($28.99 @ Mwave Australia)
-Case: NZXT Phantom 530 White ATX Full Tower Case  ($169.00 @ Mwave Australia)
-Power Supply: Silverstone Strider 600W 80+ Silver Certified Fully-Modular ATX Power Supply  ($109.00 @ PCCaseGear)
-Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer
-Operating System: Microsoft Windows 8.1 - OEM (64-bit)  ($115.00 @ CPL Online)
Total: $1881.99
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-01-25 23:17 EST+1100)
1. Budget & Location: Anywhere under AU$1900, really. Australia.
2. Aim: Pretty much just Gaming. I don't really stick to any one type of game, so being able to run anything up to FarCry 3 and Crysis 2 would be ideal.
3. Monitors: I'm still deciding what monitor I want specifically. Probably just 1 at first, but looking to move up to two at some point. Don't really have a preference towards 1080p or 1440p.
4. Peripherals: As I said before, still looking at monitors, so any suggestions would be great. Other than that everything is sorted.
5. Why are you upgrading? My laptop just doesn't cut it anymore.
Other Information: Kind of on the fence as to what case I want to go for. I do like the NXZT Phantom sort of look but not sure if the 530 is the best option. Also, to the best of my knowledge, I should be able to fit the Noctua NH-D14 with my Mobo and memory but if i'm wrong there, let me know.
Thanks.
https://linustechtips.com/topic/106703-first-gaming-build/
Maybe I would change the cooler to H100i. With that thing cooling your CPU, you'll be able to achieve high overclocks. Maybe I'd add 2 NF-F12 in pull on it.
And the mobo: maybe Maximus VI Formula from ASUS?
Sorry for my bad English!
i5-4590 | Sabertooth Z97 mk2 | Intel HD 4600 | ADATA XPG V1 2x4GB 1600MHz CL9 | Intel 530 120GB | Cooler Master N600 | Seasonic G-450 | Focusrite Scarlett 2i4 | Win8.1 Pro x64
https://linustechtips.com/topic/106703-first-gaming-build/#findComment-1426403
Seems like you could go a little cheaper on the motherboard and go for the R9-290 instead of the 280x. But from a glance at PC part picker, there don't seem to be any aftermarket ones, so bear that in mind. You could try and save some more to get the 780, but that would be a little trickier.
Also, I really don't know much about SilverStone PSU's. There are a few options for Antec, Corsair, or SeaSonic at that price though, you could get something like http://au.pcpartpicker.com/part/antec-power-supply-hcg620 which is supposed to be a very good series of PSU's.
EDIT: Here's my stab at it:
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($275.00 @ CPL Online)
Motherboard:  MSI Z87-G45 Gaming ATX LGA1150 Motherboard  ($195.00 @ CPL Online)
Storage:  Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($99.00 @ CPL Online)
Video Card:  Gigabyte Radeon R9 290 4GB Video Card  ($519.00 @ PCCaseGear)
Total: $1900.99
(Generated by PCPartPicker 2014-01-26 01:56 EST+1100)
https://linustechtips.com/topic/106703-first-gaming-build/#findComment-1426443
https://linustechtips.com/topic/106703-first-gaming-build/#findComment-1431126
Mind explaining the reasoning behind some of the changes?
Thanks.
The Havik 140 is cheaper and performs just as well as the NH-D14. It fits the look of the white Phantom better as well. It's a bit louder but it isn't really louder than the stock case fans so it shouldn't really be a problem.
Cheaper motherboard/ram to match the general theme of the Phantom 410 case.
280x has a blue pcb to match the theme. It was also one of the cheapest 280x's I could find.
Cheaper wifi card/case to save money. I also don't see why you'd need a full tower for this type of build.
It was generally just to lower costs to fit the budget. If you haven't noticed, the list you posted doesn't give a price for the 280x and the optical drive.
https://linustechtips.com/topic/106703-first-gaming-build/#findComment-1433049
Thanks for your help, will look into some of these changes when i get the time.
https://linustechtips.com/topic/106703-first-gaming-build/#findComment-1436018
