The stock cooler ain't enough?
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1066692-air-or-liquid/#findComment-12593674
Just now, Antman507 said:
nah, when i launch a game like subnautica it struggles a bit
Fair enough, where are you from and how much are you willing to spend?
Personal Desktop":
https://linustechtips.com/topic/1066692-air-or-liquid/#findComment-12593682
Personal Desktop":
https://linustechtips.com/topic/1066692-air-or-liquid/#findComment-12593701
LTT a bit ago released a video that had an air cooler beating out liquid in both performance and volume, but imo I'd go air just for reliability. Liquid really only wins (imo) in aesthetics and performance when you put a lot of money into it (not AIOs).
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/1066692-air-or-liquid/#findComment-12593737
On 5/24/2019 at 4:14 PM, Antman507 said:
Im in the UK and looking to spend under £80
What case and ram are you using?
https://linustechtips.com/topic/1066692-air-or-liquid/#findComment-12596281
30 minutes ago, Antman507 said:
Phanteks P300 and some HyperX Predator
If you're not oc'ing much, a DR4 should be plenty for cooling and be very quiet: https://uk.pcpartpicker.com/product/FRYLrH/be-quiet-dark-rock-4-cpu-cooler-bk021
If you want more headroom, the NH-D15S and LGMRT are good 'overkill' options.
https://uk.pcpartpicker.com/product/xCL7YJ/noctua-cpu-cooler-nhd15s
https://uk.pcpartpicker.com/product/B8rcCJ/thermalright-cpu-cooler-legrandmachort
https://linustechtips.com/topic/1066692-air-or-liquid/#findComment-12597676
