USA? - Is it the 800$ for everything including monitor and peripherals?
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1066672-my-first-pc/#findComment-12593455
If its just the desktop I would do something like this:
No windows included. You can get a key for like $10
https://linustechtips.com/topic/1066672-my-first-pc/#findComment-12593473
-Moved to New Builds and Planning-
https://linustechtips.com/topic/1066672-my-first-pc/#findComment-12593518
I would personally advise against the 1TB SSD and 3000Mhz memory.
Everything else you listed looks good, though.
https://linustechtips.com/topic/1066672-my-first-pc/#findComment-12593520
I figured the ssd would be better for most, rather than getting a 256gb ssd and hard drive. Especially since it’s his first gaming computer, he probably won’t have a huge steam library. I went with the 3000mhz ram because going with cheaper ram wouldn’t have made a difference in what cpu or gpu he could get. I also tend to favor ssd’s and fast ram though :)
https://linustechtips.com/topic/1066672-my-first-pc/#findComment-12593643
