So a question to the gun people here, are the Bushmaster ACR and the Magpul masada the same gun?
Google thinks they are the same in images and now im confused.
Listen if you care.
https://linustechtips.com/topic/106665-are-these-guns-the-same/
It's an ACR. Adaptive Combat Rifle and are the same models.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/106665-are-these-guns-the-same/#findComment-1425771
not entirely true, they took elements from multiple rifles to build the magpul then bushmaster took over the licence then bushmaster build all the variations from the magpul template.
so are they the same? yes and no. its like comparing different ranges of a car type compared to the prototype. similar yes but not the same. there all in the same family of rifle
Please Quote so i know you have replied. | If we have provided a solution to your problem mark it with answer found.
And also please read the COC and avoid the embarrassment and lecture that will ensue.
https://linustechtips.com/topic/106665-are-these-guns-the-same/#findComment-1425832
