I just built my PC and now there seems to be a whine coiling problem. The sound stays stagnant throughout my use and it starts once I power my PC on. It doesn't seem to come from my GPU, storage devices, or any of the fans. The only part I suspect is the PSU (Seasonic Focus G 550w 80+ gold). Should I replace it? Is there another part I should look out for? Is it just a vibrating screw?
https://linustechtips.com/topic/1066577-whine-coil-problem/
@LukeSavenije you should know if that PSU should wine or not
Builds:
https://linustechtips.com/topic/1066577-whine-coil-problem/#findComment-12592481
1 minute ago, MyEarsAreBleedingHelp said:
I've used the paper-clip method and the PSU is silent besides the fan. Can it be another component causing the coil whine?
many, but coil whine normally only really hapens under a higher load...
https://linustechtips.com/topic/1066577-whine-coil-problem/#findComment-12592745
