I can't decide between the two models,
I need a 240mm cooler
The only ones we have in my area are :
CoolerMaster Master Liquid ml240r
Silverstone TD02 rgb
And Corsair H100i pro but overpriced
So between the Silverstone and CoolerMaster which is the better option?
Life is a journey in darkness, and in darkness we seek a light to light our path thru life,
In light we seek the darkness in our lives to shade the misdeeds we do unto those we meet.
Jerry Lettins (Art teacher.)
https://linustechtips.com/topic/1066242-liquid-cooler-options/
The two seem pretty similar with a slight edge towards the TD-02 RGB.
https://whatnext.pl/test-chlodzenia-silverstone-tundra-td02-rgb/3/
http://www.enostech.com/silverstone-tundra-series-td02-rgb-cpu-liquid-cooler-review/
If you're limited to these two coolers, go with the cheaper one or the TD-02 RGB for the 3 year warranty vs. ML240R's 2 years.
https://linustechtips.com/topic/1066242-liquid-cooler-options/#findComment-12589239
