So I'm convinced that my 8700k has an absolutely brutal TIM application under the IHS. I was running it at 4.7GHz all cores with 1.250v and getting 86c in RealBench after 30 mins w/ a Kraken x62 cooler. After 30 minutes on stock frequencies at the same voltage, I got a max of 72c which is much cooler. I use my PC mainly for games @1440p with a little bit of photo editing from time to time. I was just looking for some opinion on this but given my usage, should I just keep it at stock until I eventually de lid? I'm not really sure if that kind of temp increase is worth it.
MSI Prestige 15
i5 10210u - 8GB DDR4 2666MHz - GTX 1650 Max-Q - 500GB SSD
Hinges still intact!
https://linustechtips.com/topic/1065304-keep-oc-or-wait-for-delid/
You sure your cooler is installed correctly?
That's awfully high for only 1.25v
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
I've remounted it several times including re securing the back bracket and got around the same temps each time.
MSI Prestige 15
fan profile?
6 hours ago, Jay Deah said:
82 isn’t anything to be scared of. These chips run very hot.
No, but something seems strange to get that hot from only 1.25v.
I got those temps at 4.9ghz at 1.35v with a worse cooler before my delid.
Is your ambient temp very warm?
It's pretty warm now but we got cold winters here in Canada and it was only a little lower. This is why I'm convinced that I lost the TIM lottery. There's a few other posts I've come across on other boards where people encountered the same kinds of temps with lower voltages. Luck of the draw I guess. Just to rule out cooler issues, I'm getting great idle temps with it, around 28c.
MSI Prestige 15
