So after building my pc I had some difficulties getting started. It all went fine when I had the solution to the problem and had no issues since.  Just a few minutes ago I returned home and wanted to turn on my pc. As always I had shut down everything before leaving (with the on off switich on the back off of my case off). Turned that on and then wanted to turn on my pc by pressing the on button (I knew that I had power because the rgb on my mainboard lwas lit) but instead off powering everything on it just turned everything off (lights out on mainboard etc). I was able to reproduce the same weird thing another time (same procedure to turn my pc on). After that i never had the issue again. I would be really thankfull if someone knows what the issue could be or if this is normal or something im kinda freaking out rn so yeah...
My specs if that helps:
i7-9700k
Asus GTX1070 strix
Asus Z390
2x8gb HyperX
Samsung ssd 970evo
Western digital SN500
Be quiet! Dark Base pro 900 rev.2
Dark Power 11 600w
Thermaltake Water 3.0 360 rgb
https://linustechtips.com/topic/1064994-weird-problem-with-my-pc/
