Hello,
a while ago I owned a In Win D Frame and I really loved the 90 degree rotated mainboard, it was awesome, plug something in without moving the case. Sadly the USB Port broke and I had to send it back. Afterwards I got myself a Phanteks Evolv ATX TG, a nice case, good looking and I have it for about two years at the moment. I dislike two things about it: no rotated mainboard and the temps are outright bad. Sadly, I didnt find any decent looking case with rotated mainbaord. The only decent-ish case I found is the AZZA Optima 803, but it cant fit a 360 rad. Some other cases rotate the mainboard as well, but they block off the access to the I/O.
The Case should have a rotated (atx) mainboard with direct access to the ports, enough room for a Zotac AMP extreme, space for at least one 360mm+reservoir and custom sleeved cables. I do not need any 5,25" or 3,5" bay, but I have to fit 2 SSDs. Perhaps you have any suggestions?
I thought about a benchtable and placing it next to me instead of on the floor, but I don´t know any benchtable which can fit a 360rad... (yeah, I am a little pessimistic about finding a case with rotated mainbaord, so I have to look for alternatives...)
If possible it should be 200€ max (~223USD or ~300CAD).
greetings
Dessy
https://linustechtips.com/topic/1064935-case-with-rotated-mainboard/
I know the newest Coolermaster C700P can rotate the motherboard 90º
There's also the RVX01 https://www.amazon.com/SilverStone-Technology-Motherboard-Rotation-CS-RVX01BR/dp/B01B6VNO1I?th=1
And the FT05 https://www.amazon.com/Silverstone-Aluminum-Motherboard-Micro-ATX-FT05S/dp/B00OD36PIG/?tag=anandtech01-20&th=1
On 5/26/2019 at 4:38 PM, Dessy said:
Sadly, I dont really like the three cases in terms of styling, I will probably stick with the phanteks and cut a few air holes in the front and top panel.
Not a problem. Happy DIY-ing!!
