I am building a PC and I couldn't find ANYTHING about my old cooler, it was the "dk8-00004-a1-gp" and NOT the "DK8-7G52C-A1-GP". A lot of google searching came up with nothing. All I really need to know is what the TDP was because I am reusing the CPU but I no longer have the cooler and instead have a "1a02c3w00" which has a 100 watt TDP. So basically I just need to know if the "dk8-00004-a1-gp" has a higher or lower TDP.
https://linustechtips.com/topic/1064757-cpu-cooler-help/
The coolers you're referring to are very similar. Chances are that it'll work fine but they're not very good coolers in the first place.
If you're going to get a new cooler, I'd suggest getting something better.
Moved to Air Cooling.
https://linustechtips.com/topic/1064757-cpu-cooler-help/#findComment-12575584
