Ok, so I shorted out my ATX PSU and now the voltage increases.... Some how..
I test the the 12v leads with my multimeter and the voltage just keeps increasing.... I don't know for how long. I don't know why.
But it sometimes decreases as well... Just randomly...
Its never regulated at 12v anymore
Same goes for the other voltages, 3v and 5v.
Side note: I'm using it as a charger for my lipo batteries.
https://linustechtips.com/topic/1063701-psu-increasing-voltage-help/
It's a poorly designed group regulated PSU.  Because of the mag amps, the voltages are only regulated when there is a minimum load on each.
10 hours ago, WindirBear said:
But I can replace it right? :(
Replace the PSU?  Yeah.  That's what he's telling you to do.  Throw it in the garbage and replace it.
Giving it a load balanced it out. Thanks! :))
