PC Specs:
i5 7500
GTX 1070 Founders
2x8GB 2400mhz Ram
Currently the specs listed above are what I have. Before this I had a 1050ti and the improvement in performance was not what was expected. After overclocking both ram and gpu whenever I have a game such as fortnite and OBS open at 720p/60fps and 2500kbps my whole pc starts to lock up at time. Does anyone know how to fix this?
https://linustechtips.com/topic/1063622-current-pc-issues/
Your processor is bottlenecking your GPU. Streaming and some games will impact it more over some other tasks. Overclocking your GPU made it even worse, the one thing that should be overclocked in your system is the CPU, sadly the 7500 non K is un-overclockable other than raising the voltage and setting it to run turbo, a new, better, more modern CPU is what will improve your experience and performance, Ryzens a good alternative if you are on a budget, some people also will just upgrade to a better CPU that is compatible with their current motherboard, but I don't recommend putting money into outdated parts.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1063622-current-pc-issues/#findComment-12564302
