2 minutes ago, VectorDynamo said:
the psu I had in mind was a corsair vs 650w power supply
That's a real cheapo unit, get yourself something nice to power that 2070, like a Corsair TXM or RMX. 550 watts is plenty as well.
Primary PC:
PSU tier list
How many watts do I need?
Hey guys i recently bought a new RTX 2070 graphics card and was wondering whether to go with a 550w power supply or a 650w power supply? all opinions are welcome! (the psu I had in mind was a corsair vs 650w power supply)
First off, welcome to the Forum!
There's a PSU tier list that many users here swear by and will probably be posted below.
Without knowing what CPU you have, I would recommend a 650w just to allow yourself room for overclocking or upgrades in the future. Something like Corsair's RMX, Evga's SuperNOVA G2, or anything from SeaSonic are all going to be good enough.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
Instead of getting the CHEAPEST 650W, you should get a BETTER 550W.
and that's said by the guy who designs them... you should get the point
something around cx/cxm level would probably be nice
but it depends... what are you powering?
A good quality 550w unit should suffice. What are the rest of th system specs ?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
26 minutes ago, VectorDynamo said:
My system specs are a Ryzen 5 2600, 2x8gb corsair vengeance DDR4, 1tb Seagate HDD and an RTX 2070
Even a 450W would work fine.
A 550W is more than you'll ever need.
"Hell is full of good meanings, but Heaven is full of good works"
but NVIDIA recommends a 550W I saw, also the person who had put my setup together had originally installed a vs650W, which i was thinking of upgrading for my RTX 2070, but i dont know which one, also I cant really tell if my GPU is working at its proper potential, cuz the FPS boosts are very minimal from my last GPU!
Yes, because:
a) they don't know how good the PSU is and have to account for utter shit ones such as Seasonic S12II-Bronze, older Corsair VS, most EVGA and THermaltake PSU
b) doesn't know what CPU you have and also overestimate.
VS650 isn't a particularly good unit, if we stay within Corsair, the CX 450W would have been better.
the PSU isn't the Problem with the GPU, usually. That's other things - such as Vsync for example.
49 minutes ago, VectorDynamo said:
So is the CX series a better pick?
Yes!
or are there better ones but not too much too much of a cost!
Depends on availability
in that range you get a way better PSU for just 10-15€ more than the other ones.
Same Wattage of course.
also how good is the corsair RM series?
Wich one?
RMx?? RMi??
What color is the label?
In General: do NOT buy PSU used!
Because you usually lose the Warranty for most companys.
And the Price is not worth the problems you might have.
Wich one?
RMx?? RMi??
RMx ones?! https://www.amazon.in/CORSAIR-RM1000X-ATX12V-Certified-Modular/dp/B015Q7F5AQ/ref=sr_1_4?crid=1UWL3PZ6C10RP&keywords=corsair+rm750x+power+supply&qid=1558161620&s=gateway&sprefix=corsair+rm75%2Caps%2C287&sr=8-4  this one!!
3 hours ago, VectorDynamo said:
So is the CX series a better pick? or are there better ones but not too much too much of a cost! also how good is the corsair RM series?
Get yourself a RM550x unit. Will work perfectly with your system. I have one myself - Good quality !
