Hey guys I am planning to get a build going, last time I wanted to go Intel but now, well I think Ryzen is the option for me. I am open for any suggestions in changes too, thanks! I know that the Ryzen 3rd gen are just around the corner, I might consider it, but I need this build ASAP so I really cannot wait that much.
CPU: Ryzen 5 2600
MoBo: Gigabyte Aorus B450 Elite
RAM: 2x8GB G.Skill Trident Z 3000Mhz RGB
GPU: Gigabyte RTX 2070 Windforce
PSU: Seasonic S12G 650
Case Fan: Deepcool CF120
Case: (Can you suggest anything at a $50-75 price range? Not really sure what's good in that price range, can't stretch the budget for the case anymore)
Don't worry about the Storages and the CPU Fan, I'll use the stock for now and upgrade later, storages are already bought. So what do you think guys? Thanks in advance!
"It doesn't matter how expensive or how high end your system is, what matters is that you are having fun using it to play the games you love."
https://linustechtips.com/topic/1063226-ryzen-5-build-help/
The new Ryzen Chips are rumored to be launching on July 7th.. so I would suggest waiting the 1.5 months for the launch. We will likely know on May 27th when Dr Lisa Su gives the keynote to open Computex.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1063226-ryzen-5-build-help/#findComment-12560307
you want that thing to blow up?
https://linustechtips.com/topic/1063226-ryzen-5-build-help/#findComment-12560368
Maybe? :P Thanks for the advice though, I'll check it out locally, since amazon doesn't deliver here in the Philippines for cheap, same as newegg lol
https://linustechtips.com/topic/1063226-ryzen-5-build-help/#findComment-12565635
On 5/12/2019 at 7:06 PM, _Syn_ said:
it's 2 weeks :|
I dunno, I'll try to wait it off for a bit. But I can't make promises since I really desperately need it already
https://linustechtips.com/topic/1063226-ryzen-5-build-help/#findComment-12565638
On 5/12/2019 at 7:28 PM, Sekvanod said:
if you have a case under a desk just choose the chippest with ATX support, ore just something you like, i like this one (https://www.amazon.com/AeroCool-Cylon-RGB-Acrylic-Window/dp/B079P1VBDY/ref=sr_1_4?keywords=pc+case&qid=1557660350&s=gateway&sr=8-4
Well yeah, but are there really no more choices for more efficient airflow? I'll take this one perhaps if there's none
https://linustechtips.com/topic/1063226-ryzen-5-build-help/#findComment-12565639
I would:
- Get the Aorus Pro motherboard instead of the Elite for the better audio codec (ALC1220 vs ALC892).
- Replace the PSU with something safe as Luke said.
- Choose a GPU that is made by anyone BUT Gigabyte (if you have a problem with it, good luck getting a replacement).
- Get something like the Fractal Design Focus G as a cheap case.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/1063226-ryzen-5-build-help/#findComment-12565646
yeah... i have little idea about the market there
but if you find anything, I'm happy to give my two cents
https://linustechtips.com/topic/1063226-ryzen-5-build-help/#findComment-12565656
