I know this is a very generic question... but this is my first build, so please help...
I hit the power button and nothing happened, no fan, no screen, except for a small LED on my case that lit up. All my components are newly bought from amazon, so there probably aren't any DOA components. Here is what I've done so far:
I installed ram, making sure both sides clicked in.
Installed my cpu core, following the notches on the socket.
Applied thermal paste and installed a cooler.
Screwed my motherboard to the risers on my case and added an IO shield
Wired all my front panel cables: pwr led, pwr sw, hdd led, reset, usb3, usb2, hd audio and sys/cpu fan cables to the correct headers
Installed my PSU, powering my mobo with a 24pin and my cpu with a 4+4
Installed a nvme m.2.
Finally I connected my monitor to my IO using a hdmi
I haven't added a graphics card yet.
Am I missing any steps?
https://linustechtips.com/topic/1063140-built-pc-wont-start/
I wouldn't rule that out so fast. Not like Amazon has magically lower DOA rates than other retailers.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1063140-built-pc-wont-start/#findComment-12559643
3 minutes ago, Saksham said:
what psu?
https://www.amazon.com/gp/product/B00FZLD2O0/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
At least they aren't ebay used ones...
https://linustechtips.com/topic/1063140-built-pc-wont-start/#findComment-12559645
I buy so much hardware from eBay, never had an issue like that before. Try to find out what parts may be malfunctioning, if any.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1063140-built-pc-wont-start/#findComment-12559650
