Hi all, I am planning to build a new gaming PC in the next 2-3 months that would hopefully last me a long time.
Currently, I have a pre-built PC that I bought 3 years ago and while it performs well on e-sports titles like CSGO and League, it doesn't perform as well in more demanding games without lowering the graphics settings.
My current PCs specs are:
CPU: Intel i5-6500 3.2GHz
GPU: GTX 1060 6GB
RAM: 8GB HyperX Fury DDR4 2133MHz
I am from the UK, and I have a budget of around £1500. With the new build I will be playing games such as AC Odyssey, AC Origins, Rise of the Tomb Raider, Shadow of the Tomb Raider, Witcher 3, BO4, Apex Legends, etc.
I have two 24" 1080p 144hz monitors from ASUS that I currently play on. I play on one monitor and the other is for stuff like chrome and discord.
My aim for this build is to be able to play the games listed at 1080p 144hz with high/max settings while getting (or close to) 144 fps to get the most out of my monitor. I do plan to get a 1440p 144hz monitor in the future, but not any time soon.
I'd also like to be able to OC my CPU since I am not able to do so with my current PC.
I have picked out some components using pcpartpicker: https://uk.pcpartpicker.com/list/fhtYkd
CPU: Intel i7-8700K
Cooler: NZXT Kraken X62 Rev 2
Motherboard: Asus ROG STRIX Z390-H Gaming ATX
RAM: G.Skill Trident Z RGB 2 x 8GB DDR4-3200MHz
Storage: Seagate Barracuda 2TB Hard Drive
GPU: Gigabyte RTX 2070 8GB Windforce
Case: NZXT H500i
PSU: EVGA SuperNOVA G3 650W
As for an SSD, I currently have a 500GB Samsung SSD from my current PC that I will be using in the new build.
I have also made partpicker lists using the same components but with a 2060 and 2080.
2060: https://uk.pcpartpicker.com/list/GX9ZNQ
2080: https://uk.pcpartpicker.com/list/rY9ZNQ
Currently, I am leaning towards the 2070 build because since it is closer to my budget of £1500 and the 2080 would be overkill for 1080p 144hz (i think).
One thing I'm not sure about is whether to go for the newer i7-9700K instead, but looking at reviews the i7-8700K seems to perfrom just as good for a bit less money.
Any advice on my component picks would be appreciated, I am open to changing these to allocate for a i7-9700K or perhaps a 2080 as long as it doesn't get too pricey :)
Thanks
https://linustechtips.com/topic/1062904-first-build-advice-needed/
I recommend waiting, if you can, to see what happens at Computex (Zen 2).. It's at the end of the month..
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
it's a bit past 1500 pounds, but you get the best of both worlds:
PCPartPicker Part List
CPU: Intel - Core i7-9700K 3.6 GHz 8-Core Processor  (£373.98 @ Aria PC)
CPU Cooler: ID-COOLING - Auraflow 240 RGB 74.5 CFM Liquid CPU Cooler  (£64.47 @ Scan.co.uk)
Motherboard: Gigabyte - Z390 AORUS PRO ATX LGA1151 Motherboard  (£167.99 @ AWD-IT) much better VRMs for overclocking.
Memory: Kingston - HyperX Predator RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  (£97.00 @ Box Limited)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  (£54.00)
Video Card: PowerColor - Radeon VII 16 GB Video Card  (£610.79 @ Overclockers.co.uk)
Case: Corsair - SPEC-DELTA RGB ATX Mid Tower Case  (£57.54 @ Amazon UK)
Power Supply: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  (£60.44 @ CCL Computers)
Custom: EASYDIY Sleeved Cable - Cable extension for power supply with extra-sleeved 24 PIN 8PIN 6PIN 4+4 PIN With COMBS-Red Black  (£28.58 @ Amazon UK)
Total: £1514.79
Generated by PCPartPicker 2019-05-11 08:34 BST+0100
@Herman Mcpootis is on to something here.. If you like that setup, I wouldn't wait.. That's actually pretty solid..
@Herman Mcpootis @ch3w2oy what do you think of this setup? I changed two things:
1. Swapped the Radeon VII for a Zotac 2080. It is about £20 more expensive but performs better and I like to record my gameplay using Shadow Play.
2. Swapped the case for a H500 since I really like that case.
It does come at a total of £1550 but it is something I'd be willing to spend.
