Hello Everyone,
I am starting to work on the plans for a new build for a roommate.
Currently, she has gained an interest in playing World of Warcraft, at the moment when she wants to game she has been using my computer.
She has said that she would like to get her own PC and has asked my opinion on various ones she has seen at Walmart, Bestbuy, etc..
I have been honest with her and told her the ones she has shown me have been complete garbage, and overpriced.
I have offered to help her pick out the pieces for a build and help her set it all up.
I am hoping people here can share any insights they may have on the hardware that I have selected as well as any recommendations when it comes to World of Warcraft.
Parts:
  • CPU
    • Ryzen 5 1600
  • Motherboard
    • MSI - B350 Tomahawk
  • Memory
    • Team - Dark 16 GB (2 x 8 GB)
  • Storage
    • Main drive
      • Western Digital - Blue 500 GB M.2-2280 SSD
    • Extra
      • Western Digital - Caviar Blue 1 TB
  • Video Card
    • GTX 980 ti
      • I will need to double check as its an old card I have in storage
  • Power Supply
    • Corsair 650 watts 80 + bronze
  • Case Fans
    • 4 x Corsair - CO-9050016-BLED 120mm
  • Case
    • Fractal Design - Focus G ATX mid tower (Mystic red)
If there are any comments or suggestions please let me know.
Thank you,
Dhumes05
https://linustechtips.com/topic/1061515-build-for-a-friend/
I like it, but I'd go with a B450 motherboard for upgrading to Ryzen 2 later on if she wants more oomph.
You're going to get asked about that PSU... just a heads up :)
If you have a Microcenter near you... That 1600 is $80.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 32GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 128GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1061515-build-for-a-friend/#findComment-12543982
What is the budget?
I assume Monitor and peripherals are also needed?
Having a 980ti lying around gets you a long way :D
650 W seems a bit overkill, consider lower wattage and higher efficiency and quality.
Also a b450 is probably not that much more. Maybe a asrock pro 4.
https://linustechtips.com/topic/1061515-build-for-a-friend/#findComment-12543991
I have been seeing that as a recommendation for upgrading later on to Ryzen 2. The only reason I dropped to the 350 was how she mentioned being happy with how my pc performs and it is only using a phenom x4 in it, so I was not sure if an upgrade path like that would be needed.
Living where I am the pc stores are overpriced. As for the psu I had three criteria $90 or under before tax,500 watt or greater and at least bronze certified.
https://linustechtips.com/topic/1061515-build-for-a-friend/#findComment-12544053
21 minutes ago, Manderis said:
What is the budget?
The peripheals will not be needed I will be l giving her mine until she wants to upgrade those.
As for the budget 1000 or less and the country is Canada provice quebec.
https://linustechtips.com/topic/1061515-build-for-a-friend/#findComment-12544063
I'm not going to get into that she may be happy with a performance when she doesn't know what's better out there... but you understand.
No sense in buying weak stuff when better isn't much more expensive.
Where are you that things are so overpriced? Nm, you answered it.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1061515-build-for-a-friend/#findComment-12544067
