Aim with controller... ?
Solved by Zando_,
7 minutes ago, Antoine Kamarovszki said:How's it a dumb topic? I asked if anyone knew some tips or tricks on how to improve console aiming. How's this topic dumb? Tell me...
Cause there's no secret sauce other than the 'ole "git gud". You're shit with a controller because you haven't used one before, same as console bois swapping to PC often have trouble with the mouse and keyboard at first. You just have to slog through it and eventually acclimatize or go back to M/KB, those are pretty much your options.
