Solution To My Problem?
Go to solution Solved by antoainb,
Have a look at this.
So i have a problem its not a big one but kind of annoying. Alright so i have the NZXT Phantom 820 and i love it! Now my mother board only has 2 usb 2.0 slots in it. While the case has 3. Also i have the Corsair H100i and that needs one. In total I need 4 USB 2.0 slots on the mother board there only is 2.
This is my mother board.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128671
Is there a Y spliter or any device that will give it more than just those 2?
https://linustechtips.com/topic/106123-solution-to-my-problem/
your probably just going to have a dead usb port
Specs
https://linustechtips.com/topic/106123-solution-to-my-problem/#findComment-1418876
