Hi guys today i just bought a ryzen 5 2600 what are the ideal temps for the CPU with stock speed and stock fan
my idle is 41 degrees but when i run the cinebench r20 it goes up to 90 degrees and the pc case is open is this normal im using the hwmonitor to see the tempsimage.png.59f4d4b77ecc3349334d7a037734e355.png
https://linustechtips.com/topic/1061172-ryzen-temps/
90C is too hot for a stock cooler and stock settings, you probably didn't install the cooler properly
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/1061172-ryzen-temps/#findComment-12540644
The Ryzen 2600 comes with the Wraith stealth cooler, 90C seems about right when running a benchmark.
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1061172-ryzen-temps/#findComment-12540646
At stock speeds the wraith stealth shouldn't have a problem with the 2600, in my experience it was around 70-80c under full load in a NZXT H500 at 30c ambient.
https://linustechtips.com/topic/1061172-ryzen-temps/#findComment-12540648
So if you are seeing up to 80C, its not hard to imagine that with rather bad airflow you could see 90.
my advice, buy a 212 Evo, or if in the UK you can grab a spire for real cheap.
https://www.aria.co.uk/Products/Components/Fans+%26+Cooling/Air/AMD+Ryzen+Wraith+Spire+RGB+Cooler+?productId=71043
https://linustechtips.com/topic/1061172-ryzen-temps/#findComment-12540654
he did say it was with a case with it's side panel open
https://linustechtips.com/topic/1061172-ryzen-temps/#findComment-12540656
That didnt show before I replied,
TL;DR, remount cooler, considering buying an improved cooler. simple.
also check what voltages that chip is getting as many AMD boards like to be heavy on the Vcore.
https://linustechtips.com/topic/1061172-ryzen-temps/#findComment-12540662
5 minutes ago, Sentrico Official said:
i already tried reinstalling and changing the thermal paste well it does decrease from 92 to 90 degrees
It's possible that the motherboard is applying too much voltage at stock, what's the clockspeed and voltage under load?
https://linustechtips.com/topic/1061172-ryzen-temps/#findComment-12540666
https://linustechtips.com/topic/1061172-ryzen-temps/#findComment-12540667
https://linustechtips.com/topic/1061172-ryzen-temps/#findComment-12540673
2 minutes ago, Sentrico Official said:
What wattage is HWMonitor reporting?
https://linustechtips.com/topic/1061172-ryzen-temps/#findComment-12540674
1 minute ago, Sentrico Official said:
Something is not right there, voltage, wattage ect is pretty low, Cant see a reason for your high temp unless you have mounted the cooler wrong...
https://linustechtips.com/topic/1061172-ryzen-temps/#findComment-12540680
90C is definitely not normal.
I have the Wraith Spire with a 1500X (similar setup) and at load, stock it's 50-60C. Hell, even at 1.425V i don't reach 90C.
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/1061172-ryzen-temps/#findComment-12540683
that's idle
Im aware its idle!
Still doesnt explain the high temps!
https://linustechtips.com/topic/1061172-ryzen-temps/#findComment-12540685
either the cooler isnt mounted right, or there is some defect in the chip, IHS or cooler that is messing with thermal conductivity.
You could just RMA the entire thing and see if a new one fixed it....
if you have another cooler try that.
https://linustechtips.com/topic/1061172-ryzen-temps/#findComment-12540692
LLC can bring the voltages way up under load, idle is not really useful, doesn't say anything
The fact its idling at 55C when its pulling 12Watts is concerning on its own.
https://linustechtips.com/topic/1061172-ryzen-temps/#findComment-12540694
