I've been trying to test an ASUS X99-S motherboard today, which has a grand total of 5 PCI-E slots, however when I try to run a graphics card (verified working elsewhere) in the bottom slot, as soon as the driver installs, the system spazzes out and crashes. Fair enough, I thought - must be a dodgy PCI-E slot. However, I also happened to have an X99-Deluxe to look at, which has a pretty much identical PCI-E slot layout. Sure enough, when I come to install a graphics card in the bottom slot, the system crashes. I've tried two different graphics cards (one Nvidia and one AMD), both known working elsewhere, and they both do this. But it would be an incredible coincidence for both of these closely related motherboards to have exactly the same fault. So I'm thinking I must be doing something else wrong, but I'm not sure what it is. Can anyone advise?
https://linustechtips.com/topic/1060616-x99-family-problems/
What kind of CPU were you using?
Because if you were using 5820K or 6800K, they don't have enough PCIe lanes for all native PCIe slots on board so some of the slots have to be routed through PCH.
"Mankind’s greatest mistake will be its inability to control the technology it has created."
https://linustechtips.com/topic/1060616-x99-family-problems/#findComment-12536531
2 minutes ago, Elwin5 said:
It's a 5820k, so does have limited lanes. Could this cause this problem, and if so how would I fix it?
You'd put the GPU in the top slot or get a CPU with more lanes. What setup are you running/trying to run?
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1060616-x99-family-problems/#findComment-12536548
